Введение
This guide will show you how to replace the battery and the soldering new wires to the motherboard. This is guide includes a highly recommend soldering guide. CAUTION: Soldering iron will be hot and may cause minor burns if handles improperly.
Выберете то, что вам нужно
Open the hatch and carefully pull out the battery to expose the cable connection
Unscrew the 4 screws from the bottom of the drone.
Unscrew the 8 screws connecting the propeller guards to the drone
Unscrew the four propeller screws.
Инструмент, используемый на этом этапе:Tweezers$4.99
Feed through opening using tweezers to grasp the wire and carefully pull through.
Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
All Done!
Еще один человек закончил это руководство.
3 Комментарии к руководству
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
