Prusa i3 MK3 X-Axis Bearings Replacement
Выберете то, что вам нужно
  1. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Belt: шаг 1, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Belt: шаг 1, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Belt: шаг 1, изображение 3 из 3
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 2, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 2, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 2, изображение 3 из 3
    • Orient the printer so that the screen is facing away from you.
    • Remove the five 2.5mm X 10mm socket head screws on the back of the extruder assembly.
    • Remove the back cover and pull it away from the extruder assembly. Do not put too much tension on the wires.
  3. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 3, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 3, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 3, изображение 3 из 3
    • Orient the printer so that the screen is facing you.
    • Loosen the 2.5mm X 18mm tension set screw.
    • Loosen the two 2.5mm X 18mm socket head screws on the right, holding on to the X-axis motor.
    • Slightly loosen the 2.5mm X 18mm pivot screw on the left. This screw will act as a pivot for the X-axis motor.
    • Pivot the motor to release the tension on the belt.
  4. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 4, изображение 1 из 2 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 4, изображение 2 из 2
    • Loosen the 2.5mm X 18mm and 2.5mm X 30mm socket head screws that hold the belt in. You do not need to remove these screws.
    • Remove the belt from the belt grips by pulling the belt towards you.
    • Un-feed the belt from its track. The belt should now be removed.
  5. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 5, изображение 1 из 1
    • During reassembly, ensure proper tension on the belt before reattaching the back cover of the extruder assembly.
    • With the extruder assembly positioned in the center of the X-axis rails, press the top of the belt with moderate pressure. The top of the belt should not be able to touch the bottom of the belt.
  6. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Carriage: шаг 6, изображение 1 из 2 Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Carriage: шаг 6, изображение 2 из 2
    • Remove the two 2.5mm X 10mm socket head screws that secure the Z-axis rod and screw bracket. Do this for both brackets.
  7. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 7, изображение 1 из 2 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 7, изображение 2 из 2
    • Lift the X-axis carriage off of the Z-axis rod and screw.
    • The X-axis motor can be removed and placed to the side for easier disassembly.
    • Be careful not to damage any of the wiring.
  8. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Bearings: шаг 8, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Bearings: шаг 8, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Bearings: шаг 8, изображение 3 из 3
    • Place the X-axis carriage on the build plate and orient it so that the front of the extruder assembly is facing you.
    • Hold the X-axis rods and pull the rod mounting bracket off of the right side of the carriage assembly.
    • Carefully slide the extruder assembly to the right off of the X-axis rods.
  9. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 9, изображение 1 из 2 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 9, изображение 2 из 2
    • Place the front of the extruder assembly on the build plate so you can access the back.
    • Locate the X-axis bearings on the back of the extruder assembly.
    • Remove the lower bearing; it is not secured by zip ties.
  10. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 10, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 10, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 10, изображение 3 из 3
    • Use the side cutters to cut the existing zip ties.
    • Pull the zip ties out of the housing and discard.
    • Remove the top two bearings from the extruder assembly.
  11. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 11, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 11, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 11, изображение 3 из 3
    • During reassembly, grease the X-axis bearings with the PRUSA Lubricant Applicator.
    • When reinstalling the X-axis bearings, the balls inside the bearings should form a diagonal "X", not a vertical "+".
  12. Prusa i3 MK3 X-Axis Bearings Replacement: шаг 12, изображение 1 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 12, изображение 2 из 3 Prusa i3 MK3 X-Axis Bearings Replacement: шаг 12, изображение 3 из 3
    • During reassembly, slide the zip ties back into the slots of the housing and tighten them to secure the top two bearings.
Заключение
To reassemble your device, follow these instructions in reverse order. Use steps 10 and 11 for reference.
Cade SmithMartin
Участник с: 01/23/24
598 Репутация
Автор 5 руководств
Команда
Western Carolina University, Team 1-5, Virtue Spring 2024 Участник Western Carolina University, Team 1-5, Virtue Spring 2024
WCU-VIRTUE-S24S1G5
4 членов
Автор 6 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 8
За последние 30 дней: 29
За всё время: 329
