Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the 3D printer on using the power switch.
Move the head to the highest position on the Z axis. This provides working room to access the head.
Heat the nozzle up. This step depends on what type of filament is currently in the machine (e.g. 190 for PLA, 220 for ABS).
Remove filament from the 3D printer.
Clean off the old nozzle with tweezers.
Remove the 1 X M3 Bolt holding on the fan shroud on the outlet of the fan.
Remove the fan shroud.
Remove the 2 X M3 Bolts holding on the blower fan.
Remove the fan and place it in a safe location.
Remove the two M3 Bolts that are holding on the Extruder Cooling Fan.
Remove the Extruder Plate carefully, and avoid touching the hot metal print head.
Use an adjustable crescent wrench and a 7mm wrench or socket to remove the old nozzle.
Screw in the new nozzle using a socket to get the threads started.
Use a crescent wrench and a 7mm wrench or socket to tighten a quarter turn past hand tight.
Insert some new filament and push it through to test the connection.
6 участников успешно повторили данное руководство.
