Puritan Bennett 840 BPS Battery Replacement
Медицинское оборудование
Ни iFixit, ни данное руководство по ремонту не одобрены и не связаны с производителем медицинского оборудования.
  1. Puritan Bennett 840 BPS Battery Replacement, BPS Battery: шаг 1, изображение 1 из 2 Puritan Bennett 840 BPS Battery Replacement, BPS Battery: шаг 1, изображение 2 из 2
    • Before beginning, ensure that the battery is drained and the ventilator is not connected to a power source.
    • Locate the breath delivery unit (BDU) shelf on the ventilator.
    • Locate the battery indicator label on the shelf to determine whether the BPS battery holds a one-hour or four-hour charge - the default for this guide is a four-hour battery.
  2. Puritan Bennett 840 BPS Battery Replacement: шаг 2, изображение 1 из 1
    • Grasp the sides of the front bezel of the BPU and gently spread them away from the ventilator.
    • Pull the bezel outward to remove it from the cart.
    • Use a Phillips screwdriver to remove the two screws that connect the BPS to the BDU shelf at the back of the cart.
  3. Puritan Bennett 840 BPS Battery Replacement: шаг 3, изображение 1 из 1
    • Using a Phillips screwdriver, remove the eleven screws securing the BPS top and front metal covers.
    • If the BPS contains a one-hour battery, only the four screws holding the one-hour battery shield (four on the top cover) need to be removed.
    • Pull the covers away from the BPS.
  4. Puritan Bennett 840 BPS Battery Replacement: шаг 4, изображение 1 из 3 Puritan Bennett 840 BPS Battery Replacement: шаг 4, изображение 2 из 3 Puritan Bennett 840 BPS Battery Replacement: шаг 4, изображение 3 из 3
    • Locate the battery indicator bracket.
    • Cut the zip tie connecting the battery harness (bundle of wires coming from the battery) to the battery indicator bracket.
    • If the ventilator contains a one-hour battery, simply disconnect the battery harness from the battery cable and lift the battery out of the BPS.
  5. Puritan Bennett 840 BPS Battery Replacement: шаг 5, изображение 1 из 1
    • Use a Phillips screwdriver to remove the two screws securing the battery retaining bracket to the rear of the BPS.
  6. Puritan Bennett 840 BPS Battery Replacement: шаг 6, изображение 1 из 1
    • Disconnect the battery connector from J2 on the circuit board next to the battery indicator bracket.
  7. Puritan Bennett 840 BPS Battery Replacement: шаг 7, изображение 1 из 1
    • Using a Phillips screwdriver, loosen the two side screws and the two base screws holding the BPS front bracket.
    • Carefully lift the battery out of the BPS.
Заключение
2 участников успешно повторили данное руководство.
Olivia May
Участник с: 01/23/20
606 Репутация
1 руководство автора
Команда
Cal Poly, Team S7-G4, Paton Spring 2020 Участник Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 членов
Автор 3 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 28
За всё время: 1,047
