Выберете то, что вам нужно
Remove the top bar by removing the 5cm hex T10 screws on the back of the device as shown. Then gently pull off the top bar from the main component.
Locate and release the flap on the side of your device's mount. This will allow you to slide the adjustable portion of the mount.
Using a #4.0 flathead screwdriver, unscrew your mount from the bottom and remove the 1.2cm screw.
Почти готово!
Заключение
