Введение
The Pyle Astro's power button is a simple push button switch that is soldered onto the main PCB. Use this guide to replace your tablet's power button.
Запчасти
Никакие детали не требуются.
  1. Using the plastic opening tool, work your way along the edge of the tablet. The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Remove the three 4 mm JIS #0 screws to release the PCB board. Remove the three 4 mm JIS #0 screws to release the PCB board.
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Flip the PCB board upside down to expose the solder joints for the power button.
  5. Install the new push button switch and solder all the connections back into place.
Заключение
Andrew Redifer
Участник с: 27.03.2018
265 Репутация
Автор 2 руководств
Команда
IUPUI, Team S3-G6, Harley Spring 2018 Member of IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 5
За всё время: 35
