Введение
Attention, tailors! This manual offers a comprehensive guide on replacing a broken needle in your QSEW QS-1201 computerized embroidery machine. While the process is relatively straightforward, the machine may seem a bit intimidating. If you're not familiar with how it works, follow this guide, and you'll be back to embroidering your favorite items in no time. Pull up your socks and give it a try!
Before you begin, power off the machine and unplug the device from the outlet.
Выберете то, что вам нужно
Have a close look at the difference between the broken needle ( left ) and the brand-new needle ( right ).
Инструмент, используемый на этом этапе:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 3.0 mm Flathead screwdriver to loosen the screw.
Gently secure the needle with the needle nose pliers.
With a tight grip, pull down to remove the needle.
Move the needle using the pliers in a circular motion from left to right to verify it moves freely without hitting any surrounding components.
You're all set to use your embroidery machine!
