Qualcomm QCP-2760 Motherboard Replacement
Выберете то, что вам нужно
  1. Qualcomm QCP-2760 Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: шаг 2, изображение 1 из 2 Qualcomm QCP-2760 Motherboard Replacement, Rear Backing: шаг 2, изображение 2 из 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Motherboard Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Motherboard Replacement: шаг 4, изображение 1 из 2 Qualcomm QCP-2760 Motherboard Replacement: шаг 4, изображение 2 из 2
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Motherboard Replacement: шаг 5, изображение 1 из 2 Qualcomm QCP-2760 Motherboard Replacement: шаг 5, изображение 2 из 2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
Заключение
Graham
Участник с: 09/30/14
107 Репутация
1 руководство автора
Команда
Ohio State, Team 1-4, Buehl Fall 2014 Участник Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 9
За всё время: 281
