Qualcomm QCP-2760 Screen Replacement
Выберете то, что вам нужно
  1. Qualcomm QCP-2760 Screen Replacement, Battery: шаг 1, изображение 1 из 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Qualcomm QCP-2760 Screen Replacement, Rear Backing: шаг 2, изображение 1 из 2 Qualcomm QCP-2760 Screen Replacement, Rear Backing: шаг 2, изображение 2 из 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
  3. Qualcomm QCP-2760 Screen Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Locate the four metal clips holding the motherboard onto the phone.
    • Pull the clips away from the motherboard while lifting the motherboard out of the case.
    • The motherboard is attached to the case by a fragile cable, do not apply any stress to the cable.
  4. Qualcomm QCP-2760 Screen Replacement: шаг 4, изображение 1 из 2 Qualcomm QCP-2760 Screen Replacement: шаг 4, изображение 2 из 2
    • Place the motherboard down so that the screen is facing up.
    • Grab the small brown connector plug at the sides with a fingernail or tweezers and flip it up.
    • Locate, but do not disconnect, the four screen clips.
  5. Qualcomm QCP-2760 Screen Replacement: шаг 5, изображение 1 из 2 Qualcomm QCP-2760 Screen Replacement: шаг 5, изображение 2 из 2
    • Flip the motherboard over so that the screen is facing down.
    • Again, be careful not to put stress on the speaker cable.
  6. Qualcomm QCP-2760 Screen Replacement, Screen: шаг 6, изображение 1 из 1
    • Use your fingers to pull back the clear plastic clips
    • The clips are fragile. Use caution when removing screen.
Заключение
Еще один человек закончил это руководство.
Xavier
Участник с: 10/02/14
313 Репутация
Автор 3 руководств
Команда
Ohio State, Team 1-4, Buehl Fall 2014 Участник Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 14
За всё время: 455
