Quantum Axis A23 Motherboard Replacement
Выберете то, что вам нужно
  1. Quantum Axis A23 Motherboard  Replacement, Removing the Case: шаг 1, изображение 1 из 1
    • Use plastic opening tools to pry open the rear casing of the your Quantum Axis A23. Slide the tool along the edges to release the plastic tabs.
    • Be careful not to crack front screen in the process.
  2. Quantum Axis A23 Motherboard  Replacement, Unscrewing the Motherboard: шаг 2, изображение 1 из 1
    • Remove all three screws holding down the motherboard, using the Phillips #00 Precision Screwdriver and slot in the Phillips Head PH #0.
  3. Quantum Axis A23 Motherboard  Replacement: шаг 3, изображение 1 из 1
    • Using the small needle nose pliers, carefully remove the small yellow ribbons that are attached to the motherboard.
  4. Quantum Axis A23 Motherboard  Replacement: шаг 4, изображение 1 из 2 Quantum Axis A23 Motherboard  Replacement: шаг 4, изображение 2 из 2
    • Cut the red and black wires that connect the battery, screen, camera, and speakers to the motherboard.
  5. Quantum Axis A23 Motherboard  Replacement, Screwing the Motherboard Back On: шаг 5, изображение 1 из 2 Quantum Axis A23 Motherboard  Replacement, Screwing the Motherboard Back On: шаг 5, изображение 2 из 2
    • Take the the new motherboard and screw it in with the screws used on the previous motherboard, starting with the top right and bottom left corners.
    • Screw on the top left corner last
  6. Quantum Axis A23 Motherboard  Replacement: шаг 6, изображение 1 из 1
    • Strip both the red and black wires in the middle with a wire stripper/cutter tool. Do this for all wires that were cut, as well as for the wires on your new motherboard.
  7. Quantum Axis A23 Motherboard  Replacement: шаг 7, изображение 1 из 1
    • Take the red wire from the specified part and attach to the red wire on the motherboard, then twist the two ends together and wrap in electrical tape. Repeat this step for the black wires.
    • Do this for every part that was attached to the motherboard.
Заключение
Snap the rear case back on to finish this repair.
Nicole
Участник с: 01/12/15
407 Репутация
Автор 4 руководств
Команда
USF Tampa, Team 1-5, Tanski Winter 2015 Участник USF Tampa, Team 1-5, Tanski Winter 2015
USFT-TANSKI-W15S1G5
3 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 356
