Quantum View 10.1 Keyboard connector solid state board Replacement
Выберете то, что вам нужно
  1. Quantum View 10.1 Keyboard connector solid state board Replacement, Open Quantum View case: шаг 1, изображение 1 из 1
    • Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
  2. Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the electrical tape and magnets.: шаг 2, изображение 1 из 2 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the electrical tape and magnets.: шаг 2, изображение 2 из 2
    • Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
  3. Quantum View 10.1 Keyboard connector solid state board Replacement, Unhooking the battery: шаг 3, изображение 1 из 2 Quantum View 10.1 Keyboard connector solid state board Replacement, Unhooking the battery: шаг 3, изображение 2 из 2
    • Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
  4. Quantum View 10.1 Keyboard connector solid state board Replacement, Removing cover plate: шаг 4, изображение 1 из 3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing cover plate: шаг 4, изображение 2 из 3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing cover plate: шаг 4, изображение 3 из 3
    • Using a PH00 Philips screwdriver bit remove 5 screws from the cover on top of the keyboard solid state board.
    • Then place cover off to the side.
  5. Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the keyboard  solid state board: шаг 5, изображение 1 из 3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the keyboard  solid state board: шаг 5, изображение 2 из 3 Quantum View 10.1 Keyboard connector solid state board Replacement, Removing the keyboard  solid state board: шаг 5, изображение 3 из 3
    • Using a PH000 Philips screw driver bit remove the two screws on securing the board to the case.
    • Then using a plastic opening tool slowly and carefully wedge the tool between the cable ribbon and the black connector portion. Then carefully rock the tool up and down to lift the connector hinge.
    • The board can now be removed.
Заключение
stephen Munchinsky
Участник с: 04/01/17
786 Репутация
Автор 7 руководств
Команда
Gateway Community College Team 1 BPC270 36301 Участник Gateway Community College Team 1 BPC270 36301
Community
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 227
