Выберете то, что вам нужно
Start by turning the tablet over with the screen down. Carefully use a plastic opening tool to pry the cover off. Start from the corner opposite the hibernate button.
Pick up the magnets from the bottom edge of the tablet next to the keyboard connection and put them in a place that they will not get lost. Then carefully remove all 4 strips of electrical tape.
Using a small plastic opening tool; genteelly pull the connection off of the motherboard.
Peel back the yellow clear tape. Followed by the use of a plastic opening tool to release the ribbon connection.
Using tweezers genitally pull up on the volume button board to remove.
Еще один человек закончил это руководство.
