Введение
A missing or broken pull on a zipper can make life difficult when you try to open and close your Patagonia jacket. This guide will show you a quick-fix method you can use in the field or as an interim solution until you can replace your slider. Don't have a zipper pull? A loop of very thin cord or string will not only work, but make MacGuyver proud.
For replacement parts or further assistance, contact Patagonia Customer Service.
Инструменты
No tools required.
Запчасти
  1. Grab your zipper pull. Thread the cord of the zipper pull through the hole on the slider where the pull used to be. Thread the cord of the zipper pull through the hole on the slider where the pull used to be.
    • Grab your zipper pull.
    • Thread the cord of the zipper pull through the hole on the slider where the pull used to be.
  2. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Make a loop with the cord that has passed through the hole. Feed the rubber end through the loop.
    • Make a loop with the cord that has passed through the hole.
    • Feed the rubber end through the loop.
  4. Pull the rubber part through the loop, then pull it tight. Pull the rubber part through the loop, then pull it tight. Pull the rubber part through the loop, then pull it tight.
    • Pull the rubber part through the loop, then pull it tight.
Финишная черта
4 участников успешно повторили данное руководство.
Brittany McCrigler
Участник с: 05.03.2012
80 640 Репутация
Автор 132 руководств
Команда
iFixit Member of iFixit
Community
109 членов
Автор 7 717 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 7
За 7 дней: 47
За 30 дней: 165
За всё время: 7,033
