Введение
This guide will talk you through the process of replacing the battery in your RCA 10 Viking Pro RCT6K03W13.
Выберете то, что вам нужно
Remove the two Phillips #00 screws to the left and right of the keyboard connector.
Work around the outside of the chassis, using the spudger to pry the backplate off.
Remove the tape over the connectors on the motherboard and other side of the battery.
Disconnect the red and black keyboard wires connecting the battery to the motherboard.
Disconnect the black ribbon cable running over the battery. Flip up the black clamp and pull the cable out.
Remove the cable over the battery connecting the motherboard and the power connector.
5 участников успешно повторили данное руководство.
4 Комментариев
You can get a battery from Amazon or Walmart.com your wellcome ?
How much voltage should the battery put out in order for the tablet to turn on?
How much
How much
