Введение
Use this guide to replace the front or back camera on a RCA Apollo 8 tablet.
Выберете то, что вам нужно
Insert an iFixit opening tool into the gap between the tablet and back panel.
Using a combination of iFixit opening tools and iFixit opening picks, pry the tablet upward around its perimeter to release it from the plastic rear case.
Release the gold and black tab from the battery that's attached to a gray wire. The gold tab is held down by an adhesive; pull it until the adhesive releases.
Remove the yellow tape that is around the battery.
Unlock the ZIF socket and detach the display data interconnect cable from the front panel assembly.
Remove the front facing and back facing cameras from the top of the tablet.
