Введение
If you have any problems due to a bad motherboard, this guide will instruct you how to replace it.
  1. Remove the 6-7.9mm ph#0 screws on the back and bottom. Remove the one 3.8mm ph#0 screw on the bottom.
    • Remove the 6-7.9mm ph#0 screws on the back and bottom.
    • Remove the one 3.8mm ph#0 screw on the bottom.
    • Remove the two 7.5mm ph#0 screws on the back and bottom.
  2. Remove 5.8mm ph#1 screw from the side button panel. Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
    • Remove 5.8mm ph#1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
  3. Pry along the seam on the top side near the buttons with a spudger. Pry along the seam on the top side near the buttons with a spudger.
    • Pry along the seam on the top side near the buttons with a spudger.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Pull the left panel away from the rest of the camcorder. Unplug the red speaker cable located at the rear of the device.
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
  6. Pull back the plastic tabs along the edges of the motherboard. Disconnect all the cables along the left side of the motherboard.
    • Pull back the plastic tabs along the edges of the motherboard.
    • Disconnect all the cables along the left side of the motherboard.
  7. Disconnect all cables along the bottom of the motherboard. Pull the motherboard away from the camcorder.
    • Disconnect all cables along the bottom of the motherboard.
    • Pull the motherboard away from the camcorder.
  8. Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
    • Desolder the two black wires holding the motherboard to the camcorder using a soldering iron.
Заключение
Oliver Adams
Участник с: 19.01.2011
620 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 6
За всё время: 2,205
