Введение
Replacing the onboard speaker for the RCA CC310.
Выберете то, что вам нужно
Remove the six 7.9mm Phillips #0 screws on the back and bottom.
Remove the one 3.8mm Phillips #0 screw on the bottom.
Remove the two 7.5mm Phillips #0 screws on the back and bottom.
Remove 5.8mm Phillips #1 screw from the side button panel.
Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
Pull the left panel away from the rest of the camcorder.
Unplug the red speaker cable located at the rear of the device.
Locate the speaker on the removed panel. Find the groove on the top left side of the speaker.
Pry the plastic up with a spudger until the glue breaks and the speaker is detached.
