Запчасти
Никакие детали не требуются.
  1. Remove these two  2.5mm Phillip's head screws before attempting to remove the screen from the device. Remove these two  2.5mm Phillip's head screws before attempting to remove the screen from the device.
    • Remove these two 2.5mm Phillip's head screws before attempting to remove the screen from the device.
  2. Run an opening pick around the edge of the screen to loosen it and begin to pry upward. When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • Run an opening pick around the edge of the screen to loosen it and begin to pry upward.
    • When the screen comes up like it has in the photo, it should be able to simply be removed from its casing.
    • The buttons on the end of the device will be loose when you remove the screen from the backplate. Be careful not to lose them.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
    • The camera is located in the corner of the motherboard, attached by a ribbon cable. Lift up on the black latch that is holding in the ribbon cable and the cable should pop up and out.
    • Do not use force to try to remove the ribbon cable. The latch may not be lifted up completely, and force can break the ribbon cable away from its connector.
  5. Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
    • Once the cable is removed from the motherboard, the entire camera can simply be removed from the device.
Заключение
2 участников успешно повторили данное руководство.
Ryan Williams
Участник с: 27.01.2015
1 100 Репутация
Автор 4 руководств
Команда
Pasco Hernando, Team 1-2, Prince Winter 2015 Member of Pasco Hernando, Team 1-2, Prince Winter 2015
PHSC-PRINCE-W15S1G2
6 членов
Автор 8 руководств
Один комментарий
Where can I get the replacement parts (camera and flex cable)
tuesday cannon - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 4
За всё время: 871
