Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide may be of use if the sound no longer works properly. For speaker accessibility, the battery will have to be removed.
  1. Remove nine 4.8mm screws around the case with a JIS #00 screwdriver. Remove nine 4.8mm screws around the case with a JIS #00 screwdriver. Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
    • Remove nine 4.8mm screws around the case with a JIS #00 screwdriver.
  2. Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
    • Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
  3. Remove cover completely. Remove cover completely. Remove cover completely.
    • Remove cover completely.
  4. Disconnect battery cable from the motherboard. Disconnect battery cable from the motherboard. Disconnect battery cable from the motherboard.
    • Disconnect battery cable from the motherboard.
  5. Pull the thin black keyboard connector off and set it aside. Pull the thin black keyboard connector off and set it aside. Pull the thin black keyboard connector off and set it aside.
    • Pull the thin black keyboard connector off and set it aside.
  6. Disconnect the thick black band (bus) using a plastic opening tool or fingernail. Disconnect the thick black band (bus) using a plastic opening tool or fingernail. Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
    • Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
  7. Use nylon spudger tool or plastic card to separate battery from the case.
    • Use nylon spudger tool or plastic card to separate battery from the case.
  8. Carefully peel off the battery. Carefully peel off the battery. Carefully peel off the battery.
    • Carefully peel off the battery.
  9. Disconnect the speaker cord from the motherboard. Disconnect the speaker cord from the motherboard. Disconnect the speaker cord from the motherboard.
    • Disconnect the speaker cord from the motherboard.
  10. Use the plastic spudger to slide the speaker out. Use the plastic spudger to slide the speaker out. Use the plastic spudger to slide the speaker out.
    • Use the plastic spudger to slide the speaker out.
Заключение
Akitaka Hashimoto
Участник с: 27.03.2018
495 Репутация
Автор 2 руководств
Команда
IUPUI, Team S3-G2, Harley Spring 2018 Участник IUPUI, Team S3-G2, Harley Spring 2018
IUPUI-HARLEY-S18S3G2
3 членов
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 257
