Введение
This guide may be of use if the sound no longer works properly. For speaker accessibility, the battery will have to be removed.
Выберете то, что вам нужно
Insert plastic opening tool and slide it around the edges until the cover starts to pop off. It may be necessary to go over each side multiple times in order to pop the cover off.
Disconnect the thick black band (bus) using a plastic opening tool or fingernail.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Use nylon spudger tool or plastic card to separate battery from the case.
