Введение
This guide will illustrate how to remove the speaker.
Выберете то, что вам нужно
Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
Place the plastic opening tool between the case and the screen.
Slide the tool clockwise around the case until all the clips are removed.
Desolder the two wires that connect the battery to the motherboard.
Using the blue plastic opening tool, lift the battery away from the device.
Desolder the wire connected from the speaker to the motherboard.
Pry the speaker from the casing with a plastic opening tool.
Еще один человек закончил это руководство.
