Введение
Taking apart the RCA Voyager II is pretty straightforward. Here is a short Guide.
Note that the tablet pictured has been disassembled and reassembled before.
Выберете то, что вам нужно
Starting from the top, place pick or plastic tool between the power button and screen edge and push apart slightly.
Run pick across the top to the right and then down the right side and around the rest of the tablet.
lift section out of the black casing from the bottom, lift and remove by pulling away from tablet.
Battery connection (on older models, may be soldered to board)
Front Camera
Digitizer
LCD
Speaker
Lift the black cover over all three flex cables (Camera, LCD, Digitizer) with a plastic tool.
gently disconnect all three cables with your fingers by pulling slightly
lift the board out gently
Fold board over the left side of the tablet and gently remove tape securing antenna to the case. Use a small amount of heat if necessary.
remove tape from top and bottom of the battery.
with a plastic piece, lift battery from adhesive securing it in place.
Place picks between the lcd and the plastic clips holding it in place.
The pick placement to the top left side (near the power button) is smaller and on a corner. I recommend inserting this pick last.
Gently push top right pick down to lift LCD from the clip. Run across the top and right side to further lift LCD.
Use picks as needed to separate LCD in other areas.
Once separated and loose, remove picks so you do not damage the LCD while removing it.
To remove, lift top of LCD and pull out of case away from the speaker, which is fixed to the digitizer frame.
to remove Digitizer/Glass from the frame and speaker, slide a pick under a corner between the glass and frame to loosen adhesive
35 участников успешно повторили данное руководство.
31 Комментариев
what is that flat part that has the little copper bar in the middle. What do you call that?
The LCD has a piece of copper tape on it, is that what you mean?
Bonne site merci pour tous je suis très heureux content que entrer dans ce site
Anyone know which company made this very fragile digitizer for RCA Voyager?
