Введение
There are many issues that can be caused by a faulty motor brush. If you begin to hear banging sounds coming from the motor, this could be caused by the motor brush. Fortunately, a motor brush is one of the easiest parts to replace due to is accessibility. All you need is a standard flathead screwdriver to remove a cap.
Выберете то, что вам нужно
Place down the Worm Drive Saw on a sturdy surface.
The motor brush cap is located on the side of the main housing assembly, it can be identified as a large black plastic cap with a slit running down its surface.
Using a flathead screwdriver, remove the motor brush cap from the main housing assembly.
With the cap removed, the motor brush should now be accessible.
Carefully remove the motor brush by sliding it out of the main housing assembly.
Еще один человек закончил это руководство.
