Введение
Some hard use and an accidental drop caused the handle on this leaf blower to become cracked right at the base. It can be easily fixed.
Выберете то, что вам нужно
This style of handle can become cracked at the base. In this case it was broken almost completely through and very weak, but it can be replaced. This
The replacement handle is listed as "HOMELITE RYOBI 311220001 Genuine Handle Assembly" and can be found at a couple of online parts sources. Currently (8/2021) available at Amazon, eReplacement parts & Parts Warehouse.
This view shows you the 3 alignment tabs. (see arrows on blue tape in picture) The handle slides onto these tabs. There will be no other clips or tabs.
Wire routing is also simple. Wires are pushed into grooves in the handle. Remove wire harness and switch with a gentle tug. Reassemble in reverse order. You will notice that the screw positions have a male/female fit helping with alignment.
Reinstall wire harness into handle.
Slide handle onto the 3 base tabs.
Reinstall 10 Torx screws.
