Введение
If your RYOBI AG454 is not working or turning on, your motor could be damaged. If the device is sputtering or smoke this could be a sign of motor damage. This guide explains how to detect issues in the motor. It will go through the process of how to understand that the issue is coming from the motor. It will then go through the process of taking apart the grinder so they can reach the motor. After this process, it will give the user helpful steps on how to see if the issue is fixable or not.
Выберете то, что вам нужно
Remove the five 14mm screws from the rotating handle using the Phillips #1 screwdriver.
Unscrew the two 14mm screws from the clear bracket using the Phillips #1 screwdriver.
Remove the bracket.
Remove the brush caps from each side of the body using the 4 mm flat head screwdriver.
Remove the four 20mm screws that secures the gear box using a Phillips #1 screwdriver.
Remove the four 20mm screws securing gear box case using a Phillips #1 screwdriver.
Cut the white wire that's located below the trigger in rear rotator handle with wire strippers.
Using a Phillips #1 screwdriver, remove the two screws from the bracket on the bottom of the body.
Remove the bracket from the device.
When reassembling be sure to pull the wires back through these two holes.
Carefully pull motor along with wires straight out from the body and remove it from the device.
