Введение
It is very important to remove the battery before any repairs. This ensures that the grinder will not turn on when you are replacing or fixing a part. Removing the handle makes it easier for the grinder to lay flat when you replace components within the body.
To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
