Введение
If your grinder begins to malfunction because of gear issues, it's time to replace the grinding head assembly. The link below contains the information necessary to order a replacement from RYOBI's home webpage.
Выберете то, что вам нужно
To remove the battery press down on the two buttons located on each side of the battery and pull away from the body of the grinder.
To remove the handle hold grinder with one hand and use the other hand to unscrew the handle with a counter-clockwise motion
Fully press the spindle lock button.
With the spindle lock button held down, use the wrench provided to loosen the clamp nut. Once loose, you can use your fingers to unscrew the nut completely
Remove your grinding/cutting tool by simply pulling it off the spindle.
Next remove the disc flange (a.k.a spacer) by pulling it off of the back end of the spindle.
Lift the clasp on the grinder guard. Make sure the clasp is completely loosened before proceeding.
Rotate the grinder guard so that the three notches on its interior align with the three slots on the grinding head assembly.
Once aligned, simply pull the guard off.
Remove the four 1.4 cm screws from the grinding head assembly using a Torx T20 screwdriver.
With the screws removed, the grinding head assembly can be removed from the rest of the head with a gentle pull.
