Введение
This guide demonstrates how to remove and replace a rear rack from the Raleigh M20 bicycle. This requires the removal of the old rear rack before replacing the new rear rack.
Запчасти
  1. Make sure that the bike is upright and stable.
    • Make sure that the bike is upright and stable.
    • With both hands, place the rear rack on the rear wheel of the bike. Take note of where the rear rack will attach on the bike.
    • Make sure that the rear rack is fitted on the bike.
  2. Place a screw to attach the rear rack to the frame of the tire.
    • Place a screw to attach the rear rack to the frame of the tire.
    • Tighten the screw with a philips screwdriver by turning it in a clockwise direction.
    • Repeat the steps above on the other side of the bike.
    • Place the metal holder to be even with the bar sticking out of the rear rack.
    • Line up the holes. Place a bolt to attach them together.
    • Use a philips screwdriver to tighten the bolts.
    • Do this for both sides.
    • Make sure that the rear rack is even. If it is not, redo the previous step.
    • Locate the screws on top of the rear rack. Tighten the screws using a philips screwdriver.
    • Once the screws are tightened, you are done.
Заключение
To detach the rear rack, follow the instructions of this guide in the reverse order.
Alyssa Compania
Участник с: 26.09.2012
86 Репутация
1 Guide authored
Команда
Cal Poly, Team 7-49, Forte Fall 2012 Member of Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 членов
Автор 5 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 2,361
