Введение
This guide will show you how to remove a broken or malfunctioning pedal and replace it with a new one.
Инструменты
Запчасти
  1. First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
    • First take an 8 in adjustable crescent wrench and fit it around the base of the pedal.
  2. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  3. To unscrew the chain side pedal twist the the wrench counter  clockwise. To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
    • To unscrew the chain side pedal twist the the wrench counter clockwise.
    • To unscrew the pedal that is on the side away from the chain, twist the wrench clockwise.
  4. Continue turning the wrench until the pedal detaches from the crank arm.
    • Continue turning the wrench until the pedal detaches from the crank arm.
Заключение
2 участников успешно повторили данное руководство.
William Beechinor
Участник с: 26.09.2012
124 Репутация
1 Guide authored
Команда
Cal Poly, Team 7-49, Forte Fall 2012 Member of Cal Poly, Team 7-49, Forte Fall 2012
CPSU-FORTE-F12S7G49
5 членов
Автор 5 руководств
Один комментарий
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 2
За всё время: 1,264
