Введение
This guide will give a step by step walkthrough of how to replace an old seat cushion with a new one.
Выберете то, что вам нужно
Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat.
Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground.
Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion.
Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image.
Now you are ready to reassemble the seat with your new cushion. Just follow these same steps in the reverse order. Thanks for taking the time to use this guide!
Еще один человек закончил это руководство.
