Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement
Выберете то, что вам нужно
  1. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Rubber Feet: шаг 1, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Rubber Feet: шаг 1, изображение 2 из 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Front Panel: шаг 2, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Front Panel: шаг 2, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Spacebar Metal Bar: шаг 3, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement, Spacebar Metal Bar: шаг 3, изображение 2 из 2
    • Pinch the top and bottom of the key of the metal bar that you wish to replace and gently lift.
    • Tilt the key upwards so that you may see underneath it.
  4. Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement: шаг 4, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma Spacebar Metal Bar Replacement: шаг 4, изображение 2 из 2
    • Using tweezers unfasten the metal bar from the key both places that they are connected.
    • Using tweezers unfasten the metal bar from the keyboard itself both places that they are connected.
Заключение
2 участников успешно повторили данное руководство.
Jacob Hughes
Участник с: 02/13/18
130 Репутация
1 руководство автора
Команда
University of North Texas, Team S6-G5, Thomas Spring 2018 Участник University of North Texas, Team S6-G5, Thomas Spring 2018
UNT-THOMAS-S18S6G5
4 членов
Автор 13 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 15
За последние 30 дней: 71
За всё время: 7,109
