Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement
Выберете то, что вам нужно
  1. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Rubber Feet: шаг 1, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Rubber Feet: шаг 1, изображение 2 из 2
    • Turn the keyboard over so that it is lying flat on its face.
    • Use the iFixit opening tool to pry the rubber feet off the keyboard.
  2. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Front Panel: шаг 2, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Front Panel: шаг 2, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove the six screws on the back of the keyboard.
    • Use an opening tool as a wedge between the front and back panel to pry open the front panel.
    • If the front and back panel won't separate, DO NOT use excessive force. This may result in damaging the keyboard.
    • Instead, slide the opening tool across the keyboard in between the front and back panel. Go around the edges of the keyboard until the panels disconnect.
    • Flip the keyboard over so the keys are facing up.
    • Grabbing the left and right lips of the front panel, lift both ends up, removing the front panel.
  3. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Back Panel: шаг 3, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, Back Panel: шаг 3, изображение 2 из 2
    • Use a Philips #1 Screwdriver to remove the four screws located below the keys.
    • Lift the main circuit board and flip it over, placing it on its top.
    • Be cautious of the wire connected to the USB Port Board.
  4. Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, USB Port: шаг 4, изображение 1 из 2 Razer Blackwidow Tournament Edition Chroma USB Port Board Replacement, USB Port: шаг 4, изображение 2 из 2
    • Pull on the wire connector until it disconnects from the USB port board.
    • You may use either your hands or a pair of tweezers to separate the white connection clip.
Заключение
Jonathan Stewart
Участник с: 02/08/18
301 Репутация
Автор 3 руководств
Команда
University of North Texas, Team S6-G5, Thomas Spring 2018 Участник University of North Texas, Team S6-G5, Thomas Spring 2018
UNT-THOMAS-S18S6G5
4 членов
Автор 13 руководств
Один комментарий
Where can I get another USB board? And it's possible to build one from scratch? I was thinking in upgrading to a USB C port
Eduwardo Horibe - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За всё время: 1,916
