Razer Blade 14" (2014) Screen Assembly Replacement
Выберете то, что вам нужно
    1. Razer Blade 14" (2014) Screen Assembly Replacement, Screen Assembly: шаг 1, изображение 1 из 1
      • Start by making sure your replacement assembly will work with your model. I bought this QHD assembly on eBay. This assembly includes the LCD, webcam, antenna, and touch digitizer. Before embarking, one should make sure that that a new screen assembly is necessary and will fix their problem. In my case, my LCD and touchscreen were fried.
      Спросите у FixBot
      Добавить комментарий
    2. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 2, изображение 1 из 1
      • unscrew the 10 (T5) torx screws to release the back panel. Be sure to fully drain your laptops battery or disconnect the battery before tampering with the internal components.
      Спросите у FixBot
    3. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 3, изображение 1 из 1
      • Note the LCD Cable (Green), Antenna Cable (Red), Webcam Cable (Blue), and Charging cable (Purple). These all run to the screen assembly.
      Спросите у FixBot
    4. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 4, изображение 1 из 1
      • Unplug before mentioned connectors. The webcam and charger cable may require a small pry tool. The LCD cable should disconnect with a light pull on the plastic tab. The antenna cables just pop off with some upward pressure.
      Спросите у FixBot
    5. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 5, изображение 1 из 1
      • Unscrew Phillips head screws holding screen hinge.
      Спросите у FixBot
    6. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 6, изображение 1 из 1
      • Unscrew right side screws, (you have to lift the charging port out of the case to fully release the hinge)
      Спросите у FixBot
    7. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 7, изображение 1 из 1
      • After removing screws, work the screen assembly free from the case.
      Спросите у FixBot
    8. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 8, изображение 1 из 1
      • Old screen.
      Спросите у FixBot
    9. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 9, изображение 1 из 1
      • Lower case onto replacement screen, Making sure no cables get pinched in the hinge.
      Спросите у FixBot
    10. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 10, изображение 1 из 1
      • Reconnect cables. (Route these cables in a way that would prevent getting crushed against the bottom cover)
      Спросите у FixBot
    11. Razer Blade 14" (2014) Screen Assembly Replacement: шаг 11, изображение 1 из 1
      • Replace bottom cover and check for functionality! (Markers are to protect identity of my friends and I)
      Спросите у FixBot
Финишная прямая
2 человек успешно провели ремонт по этому руководству.
Sellers Hill
Участник с: 04/13/17
128 Репутация
1 руководство автора
6 Комментарии к руководству
Just preformed the repair today with success!
The total repair took me about 30 minutes. I would suggest anyone doing this repair to buy a can of air before starting — I was amazed at how dirty my machine was under the case.
Many thanks for sharing this guide.
Caleb Dowdy - Ответить Поделиться
can you share the ebay link thanks
ALI AL-Hashmi - Ответить Поделиться
Is it possible to swap the matte screen with the glass touch screen
Kevin Chan - Ответить Поделиться
Hi i try to do this in mi razer blade 14 2017…. the model is same, spare part and all connectors are the same, but when i turn on the laptop screen is black… the logo in the back of the screen is turn on also the touch works… i plugged a monitor to the laptop and works… i touch the screen in the laptop and see it works on the monitor….
when i go to settings and try to identify screens, cant see the screen of the laptop (default) as available.
I disable and enable the drivers (device manager) both graphic cards nothing happens.
I notice the connector has this number CA12020569TH is the same in both screens (i assume was part number), but down of this number connectors had a different number, spare part is 7AR01A7 (i assume was serial num) the original i don’t have it, i re install the broken screen,
Can you help me please, the spare part is a full assembly like the one in this post. Thanks for you time if you read this and best Regards
Tomas Gerardo Thomas Paz - Ответить Поделиться
Hi Tomas Gerado,
I have the same problem. Have you solved the problem yet? Please share your experience.
Thank you,
Vinh PHAM GIA - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 15
За последние 30 дней: 63
За всё время: 12,829
