Введение
If yourRazer Blade RZ09-0130 2015 isn’t starting or its performance is lackluster, your motherboard may be damaged. Because the motherboard is the most essential component to a computer, proceed with extra caution when going through these instructions. Although other components may work as expected, they could become damaged if the motherboard is mishandled.
Выберете то, что вам нужно
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
Using the Phillips #0 screwdriver, remove the two 3mm screws from the right speaker.
Using your fingers, gently pull on the wire connecting the speaker to the motherboard until it disconnects.
Remove the connector by pulling it away from the motherboard with your fingers.
Using the Phillips #0 screwdriver, remove the four 3mm screws connecting the motherboard to the chassis of the device.
Using the Phillips #0 screwdriver, remove the three 3mm screws connecting the charging port to the chassis of the device.
Gently pull on the cables connecting the charging port to the motherboard until it disconnects.
Lift the port out of the device.
Remove the paper connector by first flipping the plastic crimp upwards and then pulling it away from the motherboard.
Repeat for the paper connector on the other side of the motherboard.
Remove the cable connecting the motherboard to the display by gently puling it upwards with your fingers.
Using a plastic spudger, push the plastic crimps holding the paper connector to the motherboard until they unlock.
Pull the paper connector away from the motherboard.
Remove the small connectors connecting the motherboard to the trackpad by first flipping up the plastic crimps and then pulling them away from the motherboard with your fingers.
Remove the two small cables connecting the display to the motherboard by lifting them away from the motherboard with your fingers.
Disconnect the last cable connecting the display to the motherboard by pulling on it gently with your fingers.
With the trackpad away from your body, lift the right side of the motherboard up.
Then, pull it up and to the right to remove the motherboard from the chassis.
