Введение
This guide outlines how to replace the WiFi card if it does not connect to the internet. If the computer does not detect any WiFi connections, the WiFi card may be damaged. Be sure there is a connection available and working before replacing the WiFi card. Some iFixit tools are required for this replacement.
Выберете то, что вам нужно
Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
Use a plastic spudger to disconnect the two coaxial antennae connectors and expose the WiFi card.
Use a Phillips #00 screwdriver to remove the single, 2 mm screw from the WiFi card.
Еще один человек закончил это руководство.
1 Комментарий к руководству
It was unnecessary for me to remove the battery. Replaced the original Killer card with a WiFi 6E Wireless Card Intel AX210 NGW Bluetooth 5.3.
