Razer Blade Stealth NVMe M.2 Upgrade
Выберете то, что вам нужно
    1. Razer Blade Stealth NVMe M.2 Upgrade, Preparing your work area: шаг 1, изображение 1 из 2 Razer Blade Stealth NVMe M.2 Upgrade, Preparing your work area: шаг 1, изображение 2 из 2
      • Grab your NVMe ssd you want to add in. Note: There is only one slot so it is recommended you clone to your new ssd before continuing
      • To do this, we recommend having a high quality kit on hand, like the ifixit one pictured
      • Have a tray to ensure you don't loose track of screws. Remember, some screws inside can be of different lengths.
      • TURN OFF THE LAPTOP and make sure you have grounded yourself. This is vital to ensure you don't damage the laptop (Or yourself)
      Спросите у FixBot
      Добавить комментарий
    2. Razer Blade Stealth NVMe M.2 Upgrade, Removing bottom plate screws: шаг 2, изображение 1 из 2 Razer Blade Stealth NVMe M.2 Upgrade, Removing bottom plate screws: шаг 2, изображение 2 из 2
      • There are only 10 screws, use the T5 bit to remove them
      • After removing the screw lift the bottom plate from the hinge, it will free easily
      Спросите у FixBot
    3. Razer Blade Stealth NVMe M.2 Upgrade, Remove stock M.2 SSD: шаг 3, изображение 1 из 3 Razer Blade Stealth NVMe M.2 Upgrade, Remove stock M.2 SSD: шаг 3, изображение 2 из 3 Razer Blade Stealth NVMe M.2 Upgrade, Remove stock M.2 SSD: шаг 3, изображение 3 из 3
      • Locate stock M.2 drive, read and take note of the yellow sticker
      • Roll sticker back (left to right) and stick it to itself so it is out of our way
      • Use PH0 driver to puncture sticker and remove SSD screw
      • Verify one last time our new SSD has the same form factor as the stock one
      Спросите у FixBot
    4. Razer Blade Stealth NVMe M.2 Upgrade: шаг 4, изображение 1 из 3 Razer Blade Stealth NVMe M.2 Upgrade: шаг 4, изображение 2 из 3 Razer Blade Stealth NVMe M.2 Upgrade: шаг 4, изображение 3 из 3
      • Insert M.2 into the slot at roughly a 30 degree angle in the depicted orientation, do not use force
      • Gently press SSD flat against the mother board with a single finger and thread the SSD screw
      • Boot into BIOS and verify drive presence
      Спросите у FixBot
Заключение
This is a very simple process make sure to count your screws and set them properly.
7 человек успешно провели ремонт по этому руководству.
Brandon Martinez
Участник с: 08/15/19
289 Репутация
1 руководство автора
7 Комментарии к руководству
You probably should’ve unplugged the battery too, just as a safety precaution before touching the hard drive
Jonathan Aldana - Ответить Поделиться
There are two spots where the battery can be disabled but given that Razer only warns about turning the unit off I doubt the battery charge will be any risk. If this was an intensive repair or replacement I would consider it a little more, but for such a quick swap it might be excessive.
Brandon Martinez - Ответить Поделиться
How much faster is the razer blade stealth with the samsumg nvme m2? Can you see or feel a difference? Would you suggest it?
Lorenzo Zimmermann - Ответить Поделиться
I can’t tell the difference, loading up games or applications it’s all the same speed, but I did not do a speed test beforehand to be 100% accurate. I also run linux so there might be a slight performance gain from that. I would include better photos of the SSD for you but I moved a few months ago and it’s still somewhere in a box.
Were there any “pre-packaged” programs that you had trouble installing or anything special programs need to run the laptop?
Ramon Sanchez - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 14
За последние 30 дней: 54
За всё время: 10,069
