Razer Book 13 NVMe M.2 SSD Replacement
Выберете то, что вам нужно
  1. Razer Book 13 NVMe M.2 SSD Replacement, NVMe M.2 SSD: шаг 1, изображение 1 из 3 Razer Book 13 NVMe M.2 SSD Replacement, NVMe M.2 SSD: шаг 1, изображение 2 из 3 Razer Book 13 NVMe M.2 SSD Replacement, NVMe M.2 SSD: шаг 1, изображение 3 из 3
    • Remove the ten screws from the back plate of the laptop using a Torx T5 screwdriver.
    • Use a bowl or collection tray to place any remaining screws inside.
  2. Razer Book 13 NVMe M.2 SSD Replacement: шаг 2, изображение 1 из 1
    • Lift the front side of the back plate.
    • Potential for device damage: Do not pull the backplate straight up, but lift it at an angle so that the backplate is just separated.
    • Lift the front edge slowly while you pry up each side.
    • Potential for device damage: There is adhesive that will be holding the backplate down and could tear.
  3. Razer Book 13 NVMe M.2 SSD Replacement: шаг 3, изображение 1 из 1
    • Slide the backplate towards you while maintaining the lifted angle.
    • Remove the hook located in the center of the back plate.
    • The hook must be removed before the backplate can be completely lifted.
  4. Razer Book 13 NVMe M.2 SSD Replacement: шаг 4, изображение 1 из 2 Razer Book 13 NVMe M.2 SSD Replacement: шаг 4, изображение 2 из 2
    • Remove the warranty sticker.
    • Unscrew the Phillips head screw holding the SSD in place.
  5. Razer Book 13 NVMe M.2 SSD Replacement: шаг 5, изображение 1 из 1
    • Lift the left edge of the SSD card using your index finger or a guitar pick.
    • The SSD will only lift a small amount. This ensures that the SSD is ready to be removed. Lifting too much can end up bending and breaking the SSD.
  6. Razer Book 13 NVMe M.2 SSD Replacement: шаг 6, изображение 1 из 1
    • Slide the SSD out of its socket by pulling it to the left while slightly lifted.
    • To get a better grip, pinch the corners of the SSD with your pointer finger and thumb.
    • Take note of the orientation of the prongs as the SSD comes out. The new SSD will need to go into the socket with the same orientation.
Заключение
4 участников успешно повторили данное руководство.
Wesley Glover
Участник с: 02/24/21
217 Репутация
1 руководство автора
Команда
University of North Texas, Team S1-G16, Raign Spring 2021 Участник University of North Texas, Team S1-G16, Raign Spring 2021
UNT-RAIGN-S21S1G16
2 членов
Автор 1 руководств
3 Комментариев
I think the "Difficulty" should be easy. It's very straight forward.
AnexBen - Ответить
Hey Wesley, I couldn't find any documentation, videos, or photos of the thermal pad placement on the Razer Book anywhere. Could you please take off the vapor chamber and take a photo of the pad placement for me? It would help me tons.
Tyrone Johnson - Ответить
Hi! I have the Razer Blade Stealth 13” Mercury White Intel® Iris™ Plus Graphics with only 256 GB PCIe M.2 SSD.
Can I upgrade this to 1TB?
Marvic Perez - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 28
За последние 30 дней: 118
За всё время: 7,291
