Введение
The optical sensor for the Razer DeathAdder Chroma is a crucial component for the device’s operation. A critical failure of the optical sensor will necessarily require a replacement.
Выберете то, что вам нужно
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Disconnect the ribbon connector between the motherboard and the optical sensor.
5 участников успешно повторили данное руководство.
2 Комментариев
Where do I get the part?
This is not a sensor, but a sensor backlight. Sensor on the underside of the main board
