Введение
The Razer DeathAdder Chroma may experience faulty scroll wheel operation, such as a stuck wheel or having a non-functional scroll wheel click. This guide will show you how to access the scroll wheel for cleaning or replacement.
Выберете то, что вам нужно
Use the blunt end of the spudger to pry the adhesive rubber pads from the top left and right edges.
Turn the mouse over so the bottom is facing down.
Separate the top casing from the bottom base by pulling the top casing upwards.
Disconnect the ribbon connector between the motherboard and the LED lights by pulling upward.
Disconnect the ribbon connector between the motherboard and the USB cable by pulling upward.
Use a Phillips #0 screwdriver to remove two 11.5 mm screws on the side buttons.
Disconnect the ribbon connector between the motherboard and the optical sensor.
11 участников успешно повторили данное руководство.
