Введение
If your keyboard isn't functioning, use this guide to replace the mainboard. This guide should take well over an hour.
The Razer Huntsman Tournament Edition is a tenkeyless mechanical keyboard.
You must know how to remove the case and switches in order to complete this guide.
Выберете то, что вам нужно
Place the unplugged keyboard on a flat, clean surface appropriate for working on.
Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
