Введение
If your port is either wobbly or non-functional, use this guide to replace it. This guide should take a half hour.
The Razer Huntsman Tournament Edition is a tenkeyless mechanical keyboard. Its USB port is easily swappable, being held in by a screw and a cable.
You must know how to remove the back of the keyboard before beginning this guide.
Выберете то, что вам нужно
Place the unplugged keyboard on a flat, clean surface appropriate for working on.
Unscrew the thirteen 6.5 mm screws, using the Phillips #0 screwdriver, that are located in the front panel.
Еще один человек закончил это руководство.
