Введение
To replace the microphone, you will have to open the speaker portion of the headset. The microphone will then be accessible. The steps detailed in this guide will can then be applied to replace the microphone. The wires will have to be soldered when reassembling the headset.
Выберете то, что вам нужно
Pull the ear cushion away from the speaker by sliding down to release the cushion from the plastic covering.
Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed.
Use the broad edge of the plastic spudger and a lot of force to pop off the speaker from the headset.
Cut both wires connecting the speaker to the headset by using a wire stripper or pair of scissors.
Use the Phillips #00 screwdriver to remove all four 9mm screws.
Rotate the screwdriver counterclockwise when removing each screw.
Slide the speaker case laterally along the length of the microphone until the casing is completely detached from the headset.
Use the Phillips #00 screwdriver to remove the 9 mm screws circled in red.
Rotate the screwdriver in a counterclockwise direction to remove each screw.
Pull the microphone out towards you until it is no longer confined within the headset.
Pull the plastic attachment with the screw-hole away from the rubber microphone casing to expose the microphone wire.
Cut the microphone wire as close to the rubber microphone casing as possible to give enough wire to work with for re-soldering the new microphone to the headset.
6 участников успешно повторили данное руководство.
9 Комментариев
I’ve come so far as the last picture but is it possible to post a picture of the cirquit board? as to where to solder the microphone to ( wich points ) since all my wires came unudone i cant tell i tried looking online for a schematic no luck.
is it possible to post a picture of the cirquit board with locations where components need to be soldered on to? all my connections became undone so im trying to figure out where each of them is attached i cannot find any schematic online.
Nice guide. But not very useful, since I can’t find any place to buy a new microphone. Has anyone found a place to buy a replacement?
