Введение
This is a step-by-step, easy-to-follow guide on how to replace the ear pad(s) on your Razer Kraken headset. This guide can also be used for the Razer Kraken Kitty and Razer Kraken Gaming headsets.
You may need this guide if any of your ear pads are old, worn out, or if you are having volume issues with the audio output from your headphones.
There are no precautions, safety hazards, or prior repair skills you need before following this guide. It is quick, easy and safe.
Pull the ear cushion away from the speaker, and slide it down to release the cushion from the plastic covering.
Continue sliding downwards around all edges of the ear cushion until the cushion is fully removed off the speaker.
Еще один человек закончил это руководство.
