Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement
Выберете то, что вам нужно
  1. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement, Scroll Wheel Encoder: шаг 1, изображение 1 из 1
    • Peel back the two teflon pads from the top corners and the one larger one from the bottom with the help of a spudger.
    • You will find four 7 mm screws under the teflon pads.
  2. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 2, изображение 1 из 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 3, изображение 1 из 2 Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 3, изображение 2 из 2
    • Gently remove the top plastic shell from the mouse.
    • Be careful when lifting the shell up to avoid damage to the cable connected to the board and shell.
    • The top shell is separate from the sides of the mouse.
    • Unplug the cable coming from the top shell that connects to the board.
  4. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 4, изображение 1 из 1
    • Gently pull the two plastic sides off the mouse.
    • Pry the sides off gently so you don't crack any of the plastic tabs that hold them in place.
  5. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 5, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the 5 mm screw holding the scroll wheel in place.
    • This screw is different than the ones at the bottom of the mouse so keep it separate.
  6. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 6, изображение 1 из 1
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 7, изображение 1 из 1
    • Gently slide the lighting chip up and out of the scroll wheel.
  8. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 8, изображение 1 из 1
    • Use a spudger to gently pry the scroll wheel assembly out from the plastic housing.
  9. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 9, изображение 1 из 1
    • Remove the scroll wheel from the holder by pushing it up from underneath.
  10. Razer Naga 2014 (Left-Handed Edition) Scroll Wheel Encoder Replacement: шаг 10, изображение 1 из 1
    • Remove the old encoder chip and replace with the new one.
    • Make sure that the silver part of the encoder faces out and that the small square points down when reinstalling.
Заключение
Tony Di Folca
Участник с: 05/13/19
231 Репутация
1 руководство автора
Команду
York University, Team S2-G6, O'Regan Winter 2021 Участник York University, Team S2-G6, O'Regan Winter 2021
YORK-O'REGAN-W21S2G6
1 член
Автор 1 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 13
За последние 30 дней: 48
За всё время: 2,025
