Выберете то, что вам нужно
Using a spudger, remove the teflon tape on the bottom of the mouse to reveal four screws.
Gently pull on the top plastic plate of the device and carefully unplug the white cord from the circuit board.
Gently pull up on the right plate on the mouse; separating it.
Carefully repeat this step for the left side.
Take your nylon spudger to gently pry the battery pack from the device.
Remove the foam on the battery shell for your new battery.
Plug the cord of the new battery into the socket found in the bottom right of the circuit board.
Insert the new battery into the battery socket.
Place the foam on the surface of the new battery (reference Step 5).
Under the battery, remove the two screws holding the battery mount in place.
Remove the battery mount.
Flip open the black pieces on either end of the white connection strip holding the side buttons onto the circuit board.
Insert the blue stripes of the new white connection strip into both white connection points.
One connection point is on the plastic plate that has the buttons. The second connection point is where the battery mount was.
2 Комментариев
Did you find the strip? Im looking or it as well.
