Razer Naga Expert MMO Motherboard Replacement
Выберете то, что вам нужно
  1. Razer Naga Expert MMO Motherboard Replacement, Top Plastic Shell: шаг 1, изображение 1 из 1
    • Peel back the two teflon tape from the top corners and the one larger one from the bottom with a spudger.
  2. Razer Naga Expert MMO Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the four 7mm screws using a Phillips #00 screwdriver.
  3. Razer Naga Expert MMO Motherboard Replacement: шаг 3, изображение 1 из 1
    • Gently remove the top plastic plate of the mouse.
    • Unplug the white cord from the circuit board.
  4. Razer Naga Expert MMO Motherboard Replacement: шаг 4, изображение 1 из 1
    • Lightly pull the two plastic sides of the mouse to remove them.
  5. Razer Naga Expert MMO Motherboard Replacement, Scroll Wheel: шаг 5, изображение 1 из 1
    • Using a Phillips #00 screwdriver, remove the 5mm screw holding the scroll wheel in place.
  6. Razer Naga Expert MMO Motherboard Replacement: шаг 6, изображение 1 из 1
    • Unplug the cord that connects the scroll wheel to the motherboard.
  7. Razer Naga Expert MMO Motherboard Replacement: шаг 7, изображение 1 из 1
    • Slide the chip out of the scroll wheel.
  8. Razer Naga Expert MMO Motherboard Replacement: шаг 8, изображение 1 из 2 Razer Naga Expert MMO Motherboard Replacement: шаг 8, изображение 2 из 2
    • Gently wiggle the scroll wheel up and back to remove the scroll wheel from the mouse.
    • Use your fingers to simultaneously push the scroll wheel and its frame forward and pull back on the plastic tab directly behind the scroll wheel until it is loose.
    • Use your thumbs to pop the scroll wheel out from its plastic frame.
  9. Razer Naga Expert MMO Motherboard Replacement: шаг 9, изображение 1 из 1
    • Place the new scroll wheel in the mount.
    • Upon reassembly, be careful to ensure the silver box on the side of the wheel is placed into the frame with the tab facing downward so upon entry into the frame it fits into its slot.
  10. Razer Naga Expert MMO Motherboard Replacement, Motherboard: шаг 10, изображение 1 из 1
    • Using a Phillips #00 screwdriver, remove all five 5mm screws that connect the motherboard to the main frame.
  11. Razer Naga Expert MMO Motherboard Replacement: шаг 11, изображение 1 из 2 Razer Naga Expert MMO Motherboard Replacement: шаг 11, изображение 2 из 2
    • Place the new motherboard in the mouse.
    • When reassembling the mouse, place the loose plastic piece that holds the scroll wheel and wire in place into the rectangular slots in the circuit board.
Заключение
Еще один человек закончил это руководство.
Jacqueline Scalzo
Участник с: 01/29/18
253 Репутация
Автор 2 руководств
Команда
University of Alabama, Team S1-G2, Bedsole Spring 2018 Участник University of Alabama, Team S1-G2, Bedsole Spring 2018
UA-BEDSOLE-S18S1G2
4 членов
Автор 5 руководств
4 Комментариев
Surprised this is rated Difficult. :f
Sumona Florence - Ответить
Do you know where I can find the motherboard for the mouse?
aldo serrano - Ответить
Where can I get a replacement motherboard?
David Mendo Diaz - Ответить
I followed these steps for the razer naga hex and it's the same. Just a tip for people that want to take off the teflon tapes, you don't need to take off the big one to the side, the only 4 screws holding the case to the top part of the mouse are under the 4 small teflon tapes in each corner. Good luck!
Vlad Gosa - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 14
За всё время: 2,161
