Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If the right or left mouse button is not responsive, the micro switch might need replacement. This guide will list all required steps to properly replace the left and/or right mouse button micro switches from the Razer Naga Trinity.
  1. Remove the interchangeable side plate. Remove the interchangeable side plate.
    • Remove the interchangeable side plate.
  2. Remove the mouse's feet using the opening pick. Remove the mouse's feet using the opening pick.
    • Remove the mouse's feet using the opening pick.
  3. Remove the four 6mm screws by using a JIS #1 screwdriver.
    • Remove the four 6mm screws by using a JIS #1 screwdriver.
  4. Separate the top mouse housing from the bottom mouse housing using the opening pick. Be careful not to tug too hard on the ribbon connector.
    • Separate the top mouse housing from the bottom mouse housing using the opening pick.
    • Be careful not to tug too hard on the ribbon connector.
  5. Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
    • Unlock the ribbon connector that is held down by the main board clips using the spudger's pointed end.
  6. Remove the side housing using the opening pick.
    • Remove the side housing using the opening pick.
  7. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  8. Remove the top housing LED 3-Pin connector that is near the main board. Remove the top housing LED 3-Pin connector that is near the main board.
    • Remove the top housing LED 3-Pin connector that is near the main board.
  9. Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board. Then pull the LED controller board upwards and out.
    • Remove one 4mm black Phillips #000 screw from the left side of the mouse holding the scroll wheel LED controller board.
    • Then pull the LED controller board upwards and out.
  10. Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
    • Pry and remove the scroll wheel feedback bar from its hold-down clips using the hook end of a halberd spudger.
  11. Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
    • Remove the scroll wheel feedback bar from the scroll wheel by holding down the spring and using angled tweezers to remove it from its placement.
  12. Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards. Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
    • Remove the scroll wheel optical encoder 3-pin connector from the main board by wiggling the connector upwards.
  13. Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out. Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out. Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
    • Using the opening tool, pry the black bracket holding the scroll wheel in place backwards until the scroll wheel housing pops out.
  14. Remove the USB Type A to 5-pin connector from the main board by pinching and pulling upwards. Remove the USB Type A to 5-pin connector from the main board by pinching and pulling upwards.
    • Remove the USB Type A to 5-pin connector from the main board by pinching and pulling upwards.
  15. Remove four 3mm JIS #1 screws holding the main board. Remove four 3mm JIS #1 screws holding the main board.
    • Remove four 3mm JIS #1 screws holding the main board.
  16. Place the tip of the soldering iron onto the micro switch contact pins. Work around the micro switch pins while prying the switch with an opening pick.
    • Place the tip of the soldering iron onto the micro switch contact pins.
    • Work around the micro switch pins while prying the switch with an opening pick.
  17. Remove and replace OMRON D2FC-F-K(50M) micro switch. Solder all three micro switch pins with soldering iron. Ensure the micro switch is bonded by performing a tug test.
    • Remove and replace OMRON D2FC-F-K(50M) micro switch.
    • Solder all three micro switch pins with soldering iron.
    • Ensure the micro switch is bonded by performing a tug test.
Заключение
2 участников успешно повторили данное руководство.
Zackary Tempert
Участник с: 16.09.2019
133 Репутация
1 руководство автора
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 44
За последние 30 дней: 205
За всё время: 1,337
