Введение
If your Razor AW Kick Scooter has a worn out wheel bar or the wheel bar is disturbing your performance, follow this guide to replace it or remove it altogether.
The wheel bar is a scooter part that can be used for performing tricks or as a footrest stand when using the scooter for transportation.
Выберете то, что вам нужно
Place the scooter on its side and on the ground.
Place the 5 mm Hex Security key into the screw, and secure the other side of the screw with another 5 mm Hex Security key to keep it from spinning around.
Remove the screw using the 5 mm Hex Security key.
Remove the screw from the scooter frame.
Remove the wheel from the scooter slowly.
Remove the black wheel holders from the scooter frame.
To reassemble your device, follow these instructions in revise order.
