Введение
Use this guide to replace the wheel hub of the Razor Hovertrax 2.0.
The wheel hub is essential for moving as it serves as the motor and wheel.
Выберете то, что вам нужно
Use a #2 Philips screwdriver to remove the eight 18.5 mm screws from the bottom of the Hovertrax 2.0.
To remove the led connector from the board, press the clip in with your fingers and gently pull up.
Disconnect the battery connector by grabbing the black side with one hand and the yellow side with the other hand and gently pull apart. (Try not to pull on the wires, it could damage them)
Remove the two 17.2 mm hex head bolts using the 4 mm hex screwdriver that secures the battery in place.
After disconnecting the battery, depending on which wheel hub needs replacing, you may need to take off the cover for the other side of the hoverboard. Using the #2 Phillips screwdriver, remove the eight 18.5 mm screws that are circled)
There are 2 wires that have to be disconnected before we can set the cover aside
To remove the connectors, press and hold the clip with your fingers and gently pull up (if it is not coming out, gently wiggle the connector side to side while pulling up)
Set the cover aside
4 connections must be removed before we can take out the motherboard covering the screws holding in the wheel hub.
To remove the connectors, press and hold the clip/connector and gently pull up (if the connector does not want to come out, gently wiggle it side to side while pulling up)
Using the #2 Phillips screwdriver, remove these four 11.6 mm screws
Lift the board up by grabbing it by the edges and set it aside.
Using the 5 mm hex screwdriver, remove the 4 (22 mm) hex bolts (no need to be gentle here, they are tight and need some force to be removed)
Use an 10 mm socket or wrench to remove the 2 bolts (13.6 mm).
After all of the bolts are removed, take the wheel hub out and set the hoverboard aside.
Now the wires must be gently pulled through the bracket so the wheel hub and bracket are separate.
