Введение
If your Elantra’s A/C hasn’t been blowing cold air for a while don’t panic. The A/C probably just needs to be recharged. In this guide, we will explain how to recharge your 2016 Hyundai Elantra A/C.
Выберете то, что вам нужно
Get refrigerant and read the pressure chart carefully. This is located on the side of the can.
Lift the hood while pulling the lever under the center of the hood. Next, prop up the hood with the hood strut.
Locate the low-pressure port by following the low-pressure hose (the cap will have an "L" on it).
While tipping the can 90 degrees back and forth, fill your vehicle (until the gauge reads as the can specifies).
To recharge your vehicle, follow these instructions in order.
